2004 blazer.
Old Dec 28, 2008 | 10:43 AM
pojazz's Avatar
pojazz is an unknown quantity at this point
Default 2004 blazer.
hi there im new to the blazer forum familer with others. im working on a friends 04 blazer. 1st problem was it wasnt starting he said he just put new plugs wires cap and rotor. found out that he didnt put the rotor screews in so that taosted the rotor. fixed that ran fine. cpl weeks later he says it just died on the road. got to looking at he truck got it to run revs bouning up and down 0 -700rpm open the throttle it backfire and die. took out the o2 sensors thinking the cats were clogged. changed the ckp sensor. nothing new dizzy and guts new ignition module. did not replace map sensor. i appear it have spark but not out the dizzy still. checked all my fuses im gonna go back with a test light today and check again. ive replaced everything that had to do with the running poorly to begin with cap, rotor, dizzy, ckp . and still there is nothing i believe the ecu is working because its still showing me a sevice engine soon light. any ideas for blazer vets. also i have no cominucation with the scan port?ecu?
Old Dec 28, 2008 | 02:59 PM
rriddle3's Avatar
Default RE: 2004 blazer.
Get the SES light code read and let us know what it is, but it sounds like a timing issue.
MTopper
Jul 12, 2011 12:19 AM
lionel2
Apr 16, 2008 04:45 PM
Chev it or leave it
Nov 22, 2006 10:08 AM
vol
Oct 30, 2006 12:10 AM
white04blazr
Suspension Tech
Oct 5, 2005 11:06 PM
