2004 Blazer 2dr rwd fuel pump swap from Tahoe fuel assembly?
I have swapped fuel pumps if they are the same physical size. I installed a 90 corvette fuel pump in a 89 s10,while I had the box off. I used the corvette because thats what I had on the shelf and it fit in the assembly. Most of what I have found is the assembly is different from car to car but the fuel pump seems to be the same size. The fuel pressure reg will adjust the amount of return back to the tank.
One thing to check is to go to an on line catalog like Rock Auto. Put in the spec.s on your 2004 Blazer. Write down the recommended AC Delco fuel pump p.n.. Then go to a Corvette 2004 fuel pump and see if the same AC Delco p.n. is listed. If yes, you are good to go.
junkmonkey
03-29-2007 08:01 PM
2FAST4U
08-13-2005 05:19 AM
