2005 Jimmy back glass will not latch shut.
Old Jun 12, 2016 | 06:23 AM
bjh65's Avatar
bjh65 is on a distinguished road
Default 2005 Jimmy back glass will not latch shut.
I opened it yesterday and when I went to shut it, the thing will not latch closed. Both buttons, inside and out, seem to be working but the glass will not shut quite all the way and will not latch at all. Anyone know what I can do about this? Thank you.
Old Jun 16, 2016 | 02:43 AM
tycobb280's Avatar
tycobb280 is an unknown quantity at this point
Did the latch get flipped over to the closed position before you shut it? You can try lubricant on it, if there dirt and stuff in there it might be keeping it from latching properly. Maybe it needs adjusted. There's probably 2 bolts and you can move it up and down. If they loosened up at all the latch could have dropped down to the point it won't catch.
Old Jul 20, 2016 | 12:14 AM
tenorsaxdude's Avatar
tenorsaxdude is on a distinguished road
I have the same issue with mine, and mine ended up being corroded. Clean it, or replace it is the best option if you can do. Best way to clean it is to pull it from the back.
Old Dec 10, 2016 | 10:17 AM
bjh65's Avatar
I ended up spraying a s^&#load of wd40 down in there and letting it set for awhile. It worked.
CTMark629
Nov 11, 2020 10:29 AM
Tantonev
Dec 28, 2012 11:56 AM
scosentino88
Jun 3, 2012 07:12 PM
abig84
Oct 9, 2009 06:14 PM
Duntov
Jun 1, 2008 05:09 PM
