3rd member Will it fit?
Old Jun 2, 2018 | 08:27 AM
gunny357's Avatar
gunny357 is on a distinguished road
Default 3rd member Will it fit?
Will the differential (3rd member) from a '99 with disc brakes fit a '95 chassis with drum brakes? Will brake fluid proportioning be correct or do I need to move the ABS module with associated plumbing also? Both are 4wd and gear ratio is the same.
Old Jun 2, 2018 | 10:06 PM
jck1961's Avatar
jck1961 is an unknown quantity at this point
I did this swap about 2 years ago and it was a direct bolt in provided you have the parking brake cables for the disc brake differential.
Old Jun 3, 2018 | 06:55 AM
gunny357's Avatar
I do have the cable.
Thanks!
Old Jun 4, 2018 | 09:48 AM
Tajohns34's Avatar
If you are replacing the rear end I would suggest looking for one with a G80, especially if that is what you already have.
Old Jun 4, 2018 | 02:55 PM
El_Beautor's Avatar
I'll second what jck1961 and Tajohns34 said. I swapped a 2001 axle with disc brakes into my 96, replacing the axle with drums. Was a direct swap, only had to bleed brakes and replace the park-brake cable, and if you can find it, having the G80 is better than an open diff.
Old Jun 5, 2018 | 07:35 AM
Tajohns34's Avatar
I have a 2000 so mine came with rear discs, and I still want to swap it for one with a G80.
Old Jun 7, 2018 | 06:16 AM
mr.vls's Avatar
I did it the hard way. I swapped in a G80 Diff into my drum brake axle, than I converted my drum brakes to rear disc from a 2000 bravado. It was a lot of work especially since I had to install and set up a new Ring & Pinion gear. My disc brakes came off a 4WD Bravada into my 89 S15 2WD Jimmy so I have the forward mounted calipers vice the rear mounted calipers. Along with the front dual piston calipers my car stops fantastic.
CPLSeraphim
May 23, 2015 08:30 AM
DimeBlazr
May 10, 2012 12:01 PM
chevygirl89
Jan 5, 2011 10:01 AM
Millertime21
Apr 14, 2008 09:18 PM
93s15jimmy
Sep 18, 2006 01:27 AM
