4.3L Fuel Lines info
Old Nov 7, 2013 | 02:34 PM
Jesster's Avatar
Jesster is on a distinguished road
Default 4.3L Fuel Lines info
I have a 96 4dr Blazer LT 4.3L and need to know about fuel line removal at the back of the LIM by the firewall. The fuel lines each have 2 nuts, one for holding the connection still (on the bracket) and one for turning to loosen the connection.
Is there a simple tool to get at these connections for removing? Could I use a couple of stubby wrenches and what sizes would I need? I have one set of fuel line rings from a Fel-Pro MS980002T LIM gasket kit, do these fit right in or are there any other washers that I would need to retain from the existing connection?
Old Nov 7, 2013 | 04:44 PM
Chevy33's Avatar
Chevy33 is on a distinguished road
Default Yes the stubbies work best
If my memory serves me it is a 16mm that rotates and a 15mm that is stationary. The o rings is all you need. They go on the lines then in.
Old Nov 7, 2013 | 04:51 PM
Do yourself a HUGE favor: Using a socket & ratchet on the crankshaft bolt, manually rotate the crankshaft clockwise until the distributor rotor is aligned with the "6" on the distributor housing BEFORE you remove the distributor. Then, DON'T bump the starter or move the crankshaft until the distributor is reinstalled back in the engine.
Old Nov 7, 2013 | 05:02 PM
Chevy33's Avatar
Default Oops
Now that is almost as funny as the response to the fart noise coming from the vents posting.
Old Nov 7, 2013 | 05:48 PM
I always take the distributor out, it makes getting at the lines a whole bunch easier.
Old Nov 8, 2013 | 03:16 PM
Jesster's Avatar
Default 1996 blazer fuel line removal
My 1996 uses a 5/8" for the small nut on the line and a 3/4" nut fixed to the mount at the back of the LIM, by the firewall. I purchased a set of SAE stubby wrenches that had both sizes for $20 at AA.
sporty982000
Aug 24, 2014 07:45 PM
Big Eazy
Apr 27, 2013 12:48 PM
skid9832004
Jun 5, 2011 01:38 PM
dj00140
Apr 13, 2011 10:48 PM
