4-HI acting up when turning sharply
Old Feb 28, 2010 | 09:24 AM
buaboi's Avatar
buaboi is on a distinguished road
Unhappy 4-HI acting up when turning sharply
2004 3 button 4WD acting like tires are scraping on something, but they are not. Its kind of a chattering when turning the wheels sharply left or right in 4-HI. No symptoms in 2-HI and I forget about it until I put it in 4-HI. Then it drives fine until I have to turn sharply or turn while backing up.
Then the front wheels chatter like crazy. 4 DR Blazer WGN 2004 V6 4.3 SEFI.
Old Feb 28, 2010 | 09:45 AM
abig84's Avatar
what kinda terrain are you turning on?
Old Feb 28, 2010 | 01:01 PM
buaboi's Avatar
just work commute, so that would be pavement.
Old Feb 28, 2010 | 01:07 PM
1998MSO's Avatar
1998MSO is on a distinguished road
That sounds pretty normal if you are turning a dry pavement.
Old Feb 28, 2010 | 01:56 PM
ABN31B's Avatar
think of it this way... in 4 hi you have 2 sets of wheels getting power....
SO when you turn sharply on something with crazy traction (like black top) you have 2 wheels pulling you where they are pointed (front) and 2 wheels pushing you forward (rear) this will cause a kind of chugging, clipping motion.... it's normal.
turning sharply (or even more than gently) in 4wd on pavement or other high traction surfaces will cause a bit of strain and a rough feel. it's normal...
Old Feb 28, 2010 | 02:34 PM
abadinalbany's Avatar
abadinalbany is an unknown quantity at this point
"Normal" but not something you should be doing if you can help it. Wears on your rings. Use 4WD only when and where necessary.
Old Feb 28, 2010 | 02:48 PM
Yep, as stated, this is completely normal. You definitely should not be trying to make this happen though. The drivetrain is binding up because the transfer case links the front and rear driveshafts together, driving them both at the same speed. When you turn, all 4 wheels take different paths. This causes drivetrain bind as the driveshafts are trying to turn at different speeds and causes the symptoms you describe.
Old Feb 28, 2010 | 04:36 PM
buaboi's Avatar
Boy I feel better now! Thank you all very much for the insight and will punch up 2-HI next time I have to make tight turns. You are the best.
Gibb
Dec 11, 2009 08:50 PM
getblazed00
Jun 14, 2006 01:18 AM
5brown1
Feb 20, 2006 09:26 PM
bfluke3
Feb 1, 2006 11:23 PM
BLAZER98
Nov 28, 2005 11:48 AM
