4 Speed Auto Transmission Blows Out Fluid
Old Nov 11, 2017 | 06:35 PM
lathechips's Avatar
lathechips is on a distinguished road
Default 4 Speed Auto Transmission Blows Out Fluid
2001, V6 I romped on it getting on the freeway and a couple miles down the road - I noticed blowing/pumping oil out. What did I do now? What model tranny do I have? I put 3 quart of universal fluid in to limp me 6 miles home. What type fluid do I replace with? How many quarts if I do a filter change? And again - What did I do?? Thanks to who reply.
Old Nov 11, 2017 | 09:04 PM
ChuckNTruck's Avatar
Auto Transmission in these trucks are a 4L60E. I like to use Dex/Merc fluid, but GM is now using a synthetic Dexron VI fluid in everything but is a bit expensive.
Can you see where the fluid is coming from?
Old Nov 11, 2017 | 09:24 PM
lathechips's Avatar
I'm letting the oil drip off before I crawl under.
Old Nov 11, 2017 | 10:56 PM
lathechips's Avatar
I just crawled out from under & noticed the lower cooling line has a pieced of rubber hose spliced in & blew a hole. Is this factory? Will a new piece of hose work? Is there enough pressure when I romped on it to pop a hole?
Old Nov 12, 2017 | 06:52 AM
LannyL81's Avatar
I have rubber hoses on the trans cooler I installed couple of years ago, so you can probably replace with some trans hose, not vacuum or low pressure fuel line hose.
Also I do not remember seeing any portion of the trans lines to the radiator being rubber, all metal. Sounds like a repair was done in the past by previous owner. I do not think the "romp" caused the hole, unless the hose used was vacuum line.
Old Nov 12, 2017 | 08:33 PM
Just get hose that is rated for transmission fluid and power steering fluid to replace that section. The pressure you see should not be more than 100 psi max in the cooler lines.
bscofield1971
Oct 28, 2013 02:47 PM
JPM
13
Apr 15, 2010 10:02 AM
mdkuni
Oct 7, 2008 10:01 AM
frayja
Oct 21, 2007 08:47 PM
v8vairman
Apr 12, 2006 01:43 PM
