4 wheel drive wont work
Old Mar 28, 2007 | 02:55 AM
jhill133's Avatar
jhill133 is an unknown quantity at this point
Default 4 wheel drive wont work
i have a 98 jimmy and the buttons on the dash just blink when i go to engage in 4wd and i can hear a click either behind the glove box or kickpanel on passenger side. any hints to the problem here maybe switch or the actuator. thanks
hillbillyinOhio's Avatar
Default RE: 4 wheel drive wont work
check your tcase fuse. if its blown, its the switch itself.
Old Mar 28, 2007 | 02:57 AM
jhill133's Avatar
i have a 98 jimmy and the buttons on the dash just blink when i go to engage in 4wd and i can hear a click down by the kick panel on the passenger side. any hints?
Old Mar 29, 2007 | 02:52 AM
jhill133's Avatar
wheres the Tcase fuse located
Old Mar 29, 2007 | 02:59 AM
it is in your fuse panel. on my 97 blazer its fuse number 19. spot is marked 4wd. left side of dash,, facing the door.
Old Mar 29, 2007 | 08:21 PM
jhill133's Avatar
the fuse isn't blown what else could it be>
Old Mar 29, 2007 | 08:29 PM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
You probably have a code stored in your TCCM....you need to groung pin 13 of your DLC and check for codes....if you are not sure what a DLC,TCCM,code or ground is...then do a search on this site it has been covered MANY times.
Old Mar 29, 2007 | 09:02 PM
Zygoat's Avatar
Zygoat is an unknown quantity at this point
it is probably the "incoder motor" or the transfer case shift motor (they are the same thing) you can get them from most auto parts stores.
mirrorimij
Jun 8, 2019 03:34 PM
wintfam@olemac.net
Jan 22, 2011 04:54 PM
lizzj70
Jun 23, 2010 06:57 PM
diceman721
Oct 25, 2009 06:53 PM
huskerman18
Oct 19, 2006 01:02 PM
