4wd fuse 98
Old Feb 4, 2014 | 06:42 PM
98blazermatt's Avatar
98blazermatt is on a distinguished road
Default 4wd fuse 98
hi my 4wd is messing up, randomly switching in and out of all the different 4 wheel drives, i heard u can take out the 4wd fuse so it wont work. took out the fuse but the liitle lights for 4wd still comes on. maybe the lights are a different fuse. idk. i just want to cut power to 4wd. gotta get to work
Old Feb 4, 2014 | 08:03 PM
richphotos's Avatar
what fuse did you pull? tccm? You can always crawl under the truck and unhook the wire harness to the transfer case
Old Feb 5, 2014 | 06:08 PM
I took the actual 4wd fuse out but now I don't have a gas reading or temp or the little green square to tell me what gear I'm in. Runs fine but I need that stuff. I was thinking maybe unplug the little box behind the right kick panel but I'm scared to fry something. My 4wd started actingfunmy after I gave sum1 a jump so my uncle pulled a differential off the bottom. Ran good for about a year in 2wd but the dash said 4hi. Then one day it started jumping all weird on take off and eventually wouldn't give gas to the engine, just rev. I got it to go into 2hi when Ihad the key on and played with 4wd buttons then randomly locked into 4lo and started to grind randomly shifting gears from park. I just pulled the fuse runs good but I'm missing gauges
Joann
Oct 14, 2013 10:33 AM
AustinBlazer
Jun 4, 2013 10:35 AM
champ186dc
Jan 9, 2010 10:34 AM
gERgMan
May 16, 2008 10:12 AM
mrblonde108
Nov 28, 2006 10:56 AM
