4WD Issue???
Old May 18, 2017 | 05:51 AM
jpmccr's Avatar
jpmccr is an unknown quantity at this point
Default 4WD Issue???
2001 Chevy Blazer LT 188,000 miles. Here's the rub. I checked my 4WD and low and behold the 4 HI light continually flashes and won't engage. I put it in 4 Lo and the light flashes but you can definitely feel it kick in. I replaced the vacuum switch on the engine fire wall and no change. I am not sure where to look next. Any/all advice deeply appreciated. Thanks...
Old May 19, 2017 | 09:46 AM
Strangerock's Avatar
Strangerock is on a distinguished road
Check the connections on the TCCM in the passenger side kick panel.....Is the service 4 wheel drive light on ?
Old May 24, 2017 | 06:59 AM
jpmccr's Avatar
It came on once. I was done for the day and shut it off. Now it hasn't come back on. Is the TCCM directly behind the kick panel?
Old May 24, 2017 | 06:42 PM
Yep, directly behind the pass kick panel. Clean any corrosion and put back together with some die-electric grease.
Old May 27, 2017 | 07:25 AM
LannyL81's Avatar
You could spend a couple of hours searching and reading the many postings on things to try. But in addition to checking the TCCM connections, remove the 4wd switch from dash, carefully separate the two halves of the switch and re-flow all the solder connections on the circuit board within, especially the connector.
Easy and pretty much $0 cost.
brian79z
32
Feb 23, 2015 07:13 PM
99bblazer99
Jun 15, 2013 08:38 PM
J.R. Clay
Mar 16, 2011 12:33 AM
extreme
Jan 5, 2010 07:29 AM
USMarine1108
Oct 18, 2009 09:47 PM
