4WD Push Button
Old Nov 20, 2011 | 01:27 PM
Teleutesl's Avatar
Teleutesl is on a distinguished road
Default 4WD Push Button
Searched the forum and been unable to locate this exact problem. We have a 2001 Blazer with typical 4wd problems. It has a 4 button push system on the dash. The 2HI works with no problem, will engage in 4HI and 4LO however the lights still flash and will not remain solid, and it will not engage period when you hit the 4WD AUTO button. Vacuums and fuses have been checked.
Old Nov 20, 2011 | 02:35 PM
pettyfog's Avatar
Any other problems at all?
Detail anything else that's not quite right.
Old Sep 11, 2012 | 02:57 PM
FsTFwRd's Avatar
I know its an old post but I have been having a similar problem with the push button 4wd. It will go in and out of 4wd just fine so far, but I have to hold the button down instead of how I used to be able to just push it once and wait for it to engage. Also, the LED indicator lights aren't working except for a second. No longer do they flash or what not. Perhaps the switch is going bad, any ideas?
Old Sep 11, 2012 | 03:23 PM
richphotos's Avatar
try pulling the tccm fuse for 30 minutes, and putting the fuse back in for the tccm relearn?
Old Sep 12, 2012 | 11:01 AM
FsTFwRd's Avatar
Ok, I'll give that a shot. thanks
Old Oct 2, 2012 | 06:59 PM
FsTFwRd's Avatar
Been a little while since I've been on, mostly due to working long hrs. I've had some time to check / test fuses and all that good stuff. I can't seem to find anything wrong with it except the above changes I mentioned. I'll try to swap out the switch on the dash and if that's not it I'll just let it go for now. It's going in and out fine as I check it once a week. So until it really breaks there's no need to worry about it. Thanks!
Tonyrodz
Dec 28, 2011 11:56 PM
tululilopo
27
Jul 2, 2010 12:04 PM
bdubs
Dec 30, 2008 02:36 PM
Blazerama
Dec 12, 2008 12:22 PM
DOUGHboy79
Aug 13, 2008 04:54 PM
