Converting All time 4wd to push button?
Old Dec 12, 2008 | 10:38 AM
Blazerama's Avatar
Blazerama is an unknown quantity at this point
Default Converting All time 4wd to push button?
Anyone have any idea as to how hard this would be?
Right now I have a 1996 All-Time 4wd blazer.
I like it for the winter, only problem is that having 4wd at all times is killing my gas mileage.
What would I need to do the conversion?
Push button selector, and all the wiring?
Old Dec 12, 2008 | 11:00 AM
WolfPack's Avatar
Default RE: Converting All time 4wd to push button?
I doubt its killing your mileage...it kinda stays in 2wd until it detects slip.
Theres plenty to look into before trying to swap it.
But...you would need a new transfer case, new front driveshaft. You would have to replace the 1 piece front passenger side axle shaft with the 2 piece passenger shaft from non-autotrac blazers, then you need a vacuum actuator or a posi-lock cable to be able to engage the front axle collar when you select 4wd...
Might I interest you in a new blazer instead?
Old Dec 12, 2008 | 11:53 AM
Blazerama's Avatar
No, it doesn't stay in 2wd until it detects a slip, I had it on the lift at work and when in drive, all four wheels were getting power.
Old Dec 12, 2008 | 12:01 PM
The earlier systems were a full time 30/70 F/R split.
The rest of what Jason has stated is true though. There is A LOT to change over.
Old Dec 12, 2008 | 12:14 PM
Blazerama's Avatar
Well, **** it then, Haha.
My 4.3 is getting higher in miles so I'll just swap a new(er) motor in and keep the All time 4wd.
Old Dec 12, 2008 | 12:22 PM
samuknow's Avatar
samuknow is an unknown quantity at this point
What kind of mileage are you getting???
Teleutesl
Oct 2, 2012 06:59 PM
Tonyrodz
Dec 28, 2011 11:56 PM
tululilopo
27
Jul 2, 2010 12:04 PM
bdubs
Dec 30, 2008 02:36 PM
DOUGHboy79
Aug 13, 2008 04:54 PM
