4x4 2001 sways at 60+ mph, hard to keep staright on lane?
Check tires for uneven wear pattern. Has a lift kit been installed or the suspension modified? Big tires? Lower ball joints are the first to go out...how many miles? Outer tie rod ends are probably next, and then everything else.
Check tire pressure. Any pulling when applying the brakes? Could be one of the caliper pistons is dragging.
Many things to check into....no one item.
mine is all over the road on the highway, to the point it is literally scarry with a dirtbike carrier in the hitch and 300+lbs in the cargo. Had it aligned and Ive just come to realize its the nature of something with a short wheelbase.
Mine has done that since new. 2002 rear wheel drive. It drifted with the original Uniroyals and replacement Michelins. Especially bad on the interstate. Dealer service found no problems. Just the nature of the beast. Runs great otherwise.
NYCJUDGE
08-28-2011 04:35 PM
Chevyboy28
06-11-2009 02:06 PM
