4x4
Old Jan 3, 2014 | 09:22 PM
ownablazer's Avatar
ownablazer is on a distinguished road
Default 4x4
Ok I have a 96 blazer push button 4x4 & when I push the button it sounds as if the vehicle is in 4x4 Trans get case is locking in but the front shaft and diff isnt?
Old Jan 4, 2014 | 07:30 AM
spittybays
Guest
Posts: n/a
Go to the BF homepage and in the google box type in 4x4 actuator. You will find every thing you need to know. Not sure if they had the four button in 96 but it makes a difference if its three or four.
https://blazerforum.com/forum/tech-a...ill-help-7180/
Old Jan 7, 2014 | 09:33 PM
sportjunkee's Avatar
sportjunkee is on a distinguished road
spittybays: I have a 98 S10 Blazer 4WD with 3 push button system (2hi, 4hi, 4lo). yesterday when I tried to us the 4x4 because of the amount of snow we received here in MI. The light on the 4hi button and 4 low button came on but the truck did not act like the 4x4 was actually working. Would this be the same issue? It was also 0 degrees. Would the extreme cold cause a problem?
Old Jan 8, 2014 | 05:08 AM
ownablazer's Avatar
I changed the vacuum actuator on top of the transfer case and fixed mine it has three spouts and threads in with a spring loaded steel ball and it will usually stick and won't lock the front end in. 7/8 wrench fits it.you can get the pay at O'riellys for like 17 bucks it will be in the help section andIf you can't find it they can go in the computer and search vaccum actuator switch.
Manteray
Oct 2, 2011 11:53 AM
razman
Feb 22, 2009 01:57 PM
sfesenko
Nov 30, 2008 08:55 PM
sdm1234
Jan 2, 2008 12:12 AM
tolleyc
Jul 29, 2007 05:57 PM
