4x4 question
Old Jun 21, 2014 | 05:02 PM
smaiwald's Avatar
smaiwald is on a distinguished road
Default 4x4 question
Hello all,
I have a 2002 Blazer with a 3 button switch for the 4WD
My 4WD has stopped working. The 2HI light is always on but when I hit the button for 4HI or 4LO nothing happens. Seems like either the switch is bad or the TCCM is bad. I figure my best bet is to go to a pick and pull and get replacements. Currently I have the 3-button switch so no Auto 4WD. If I get a 4-button switch and a TCCM from a blazer or S10 with a 4-button switch will I magically get auto 4WD? Or are the connectors differant too?
Thank you
Old Jun 21, 2014 | 06:46 PM
The transfer case is different, along with switches, wire harnesses, TCCM, etc etc.
When you select 4WD HI and 4WD LO, does the transfer case make any noises? Clicking, clunking, humming, etc.
If not, could be most anything. Without removing the fuses, check both terminals on the top of each fuse with a test light or volt meter. Also, remove the electrical connector at the TCCM and inspect for corrosion or loose terminals, same thing at the encoder motor on the transfer case.
Old Jun 21, 2014 | 09:01 PM
smaiwald's Avatar
I don't hear any noises from the transfer case but I haven't tried it with the engine off. I usually can't hear any noises with the engine on. I will check all the connections tomorrow.
Athlon2012
Dec 16, 2014 11:35 PM
razman
Feb 22, 2009 01:57 PM
sfesenko
Nov 30, 2008 08:55 PM
sdm1234
Jan 2, 2008 12:12 AM
tolleyc
Jul 29, 2007 05:57 PM
