700r4 1986 z28 off topic
Old Jan 28, 2014 | 07:12 PM
Joey1986Z's Avatar
Joey1986Z is on a distinguished road
Default 700r4 1986 z28 off topic
Hey!
Y'all been so helpful. I know this is off topic, but this trans is in our Blazers and I've gotten little response from thirdgen.org:
My original post there:
Hello,
Been a while. Looks like I haven't logged in here since Oct. 2008!
I purchased my Z28 new in 1986. It was built a year earlier September 1985. I found the build sheet 15 years after buying the car under the rear seat!
LG4/700R4.
In June 2007 the car had 336,000 miles. No major engine or trans work had ever been done to this car (got my money's worth!).
It did at that time have a small ATF leak, about a quart every month or so. It appeared to leak more when parked for a few days. It had been that way for years.
The car was stolen mid June 2007 and recovered 2 weeks later. The radio and Qjet were gone. I towed it home and had a spare Qjet around and put it on the car. Started it up and proceeded to move, car would not. Severe, spraying ATF leak from TC area. Evidently the punks (never caught) who stole it, joy rode it and blew the trans. I took the trans out and changed the $3 seal. Put it all back in and it still leaked as bad. In early 2008 I took the trans out again and replaced the $3 pump and another $3 pump seal. The leak was reduced significantly, but still a stream, and the car
could be driven a few miles until the ATF gets low. The car has more or less been parked since then. I do start it about once a year and drive it a few miles around the block. Does fine, you have to add 4-5 qts. of ATF to get it to go.
I know with this many miles, and it being sat 6 years a total rebuild is in order. I actually rebuilt my 1995 Corvette (with only half the miles [3-4 clutch pack]) 4L60E successfully so I know I can do the job; however, what is causing the leak? A bushing further down the pump? can the TC itself leak? The leak is coming from the pump/TC area.
Thanks for your help. I'd like to get this car I purchased as a teenager (now in mid forties) on the road before it rust/rots away.
Last edited by Joey1986Z; Jan 29, 2014 at 08:49 AM. Reason: Corrceted format issues
Old Jan 28, 2014 | 07:35 PM
TMShannon's Avatar
TMShannon is on a distinguished road
I had '87 S-10 (Z71 RPO by the way, kick *** little pickup) that had that problem....I could not keep that seal in, I finally took JBweld and sealed it in and then sold the pickup...not sure how long it lasted. What I was told at the time by a good trans shop was that it needed a new pump/pump housing installed.
Travis
wlorton
Nov 1, 2009 09:59 PM
JediKnight2
Feb 26, 2009 10:08 PM
slm0076
Suspension Tech
Oct 22, 2007 04:00 PM
