Notices
Off topic Engine/Head question (Van)
Old Feb 26, 2009 | 03:00 PM
JediKnight2's Avatar
JediKnight2 is an unknown quantity at this point
Default Off topic Engine/Head question (Van)
I have a 2000 Chevy Venture and it appears I have a head gasket issue. The symptoms all follow what other sites say with the floating needle from normal to red and no heat from the heater. I have already replaced the thermostat and intake manifold gaskets. KICKING myself for not doing the head gaskets at the same time...would have saved me a few hundred bucks at least.
HERE is my question...should I just AUTOMATICALLY send the heads off to be tested...or if they look good and not warped not worry about it?
Old Feb 26, 2009 | 03:54 PM
Default RE: Off topic Engine/Head question (Van)
If you are replacing the head gaskets, it pays to have the heads at least checked for flatness while they are off.
Old Feb 26, 2009 | 10:08 PM
Byte Stryke's Avatar
Byte Stryke is an unknown quantity at this point
If you don't have the time or money to do it right the first time, where will you find the time and money to re-do it the next time?
mov4x4
Dec 23, 2010 01:44 PM
wlorton
Nov 1, 2009 09:59 PM
slm0076
Suspension Tech
Oct 22, 2007 04:00 PM
