95 4.3 horrible fuel economy
Old Dec 19, 2011 | 04:00 PM
Indy95Blazer's Avatar
Indy95Blazer is on a distinguished road
Default 95 4.3 horrible fuel economy
Thnx for all previous input, Had the codes pulled by local shop, p0135,p0401,p0441, so this gives me somewhere to start. Has anyone expierenced problems with the feeder tube to egr valve rusting or plugging up? Guy at shop said its a common problem with gm. This thing bucks a little from 50-55mph but that its, below 50 its fine and above 55 its fine. Where is the egr valve located? Thnx
Old Dec 20, 2011 | 01:19 AM
Gale's Avatar
Gale is an unknown quantity at this point
Default Read up on the spider injector system too.
What does each code indicate as related systems?
Old Dec 20, 2011 | 07:20 AM
P0135 - HO2S Heater Circuit Bank 1 Sensor 1
I would start by swapping the upstream O2 sensors side to side & see if the code changes to P0155. If it does, change the O2 sensor.
P0401 - Exhaust Gas Recirculation Flow Insufficient Detected
Remove the EGR valve (center of the engine directly above the water pump) and clean it. The Tech Article on EGR cleaning will run you through the steps.
P0441 - Evaporative Emission Control System Incorrect Purge Flow
You could try cleaning the EVAP purge solenoid located on the engine near the ignition coil.
The bucking at 50-55mph could possibly be something completely unrelated, but get at least the first 2 codes dealt with and see how the truck runs.
Old Dec 20, 2011 | 08:15 AM
NOMORSTANG's Avatar
NOMORSTANG is on a distinguished road
Does it idle rough at stops?
I had a bad fuel rgulator,and was rough idle and eating gas bad..
Old Dec 20, 2011 | 03:48 PM
Im only finding 2 02 sensors one before the cat and one after. Ive been told some have 4, some have 2 and some only have 1, the tech wrote down p0135 02 heater circuit bank 1 sensor 1, if that helps any. Also my 02"s are a 4 pin plug, Counter guy ar Oreilly told me all he had were 3 pin.
Old Dec 20, 2011 | 03:51 PM
A 95 will only have 2 exactly as you have found. The 96-97's had 4 while the 98+ have 3.
Do yourself a favor and buy AC Delco O2 sensors.
Old Dec 21, 2011 | 04:05 PM
Thnx again, since I only have 2 02 sensors should i still try and swap them to see if code changes? Does one go bad more often than the other? I can get the a/c delco AFS75 02's online for 39.99 but didnt wanna buy 2 if not needing both...
Old Dec 21, 2011 | 06:46 PM
The O2 sensor closest to the engine (between the engine & the catalytic converter - called the upstream sensor) is the only one that has anything to do with fuel management in the engine so that is the only one I would recommend changing. Only change the downstream sensor if you get a code for it.
Old Jan 14, 2012 | 08:56 AM
Replaced the 02 sensor using the recommended a/c delco unit and mileage went from around 9 mpg to 14 mpg, next will be the egr cleaning. Thanks for the help.
Old Jan 14, 2012 | 09:39 AM
gojorg's Avatar
Just curious. Did the SES light was on? I have a similar problem, I'm getting 8-9 mpg on the last 2 fill ups but no SES light on or rough idle or problems starting. Anyway, my question is, can there be codes on the system without the check engine light on?
zebsadog
Mar 13, 2013 04:01 AM
ned4spd8874
Feb 10, 2011 10:48 PM
Lanel
Jan 16, 2010 07:22 PM
Mariongo
Jan 15, 2007 06:13 PM
Blisteredheel
Aug 6, 2005 10:01 PM
