95 Blazed No Start
I finally got the blazer to start but I have a concern if others have experienced a condition relating to the fuel pressure regulator. I purchased a regulator from Auto Zone, installed it and the truck started. Drove great for a day then the original problem resurfaces. Replaced the regulator again (warranty) and the truck ran great for four days then the problem reappeared once again. Replaced a third regulator yesterday and the vehicle runs but it has a hesitation. My question is would there be something that makes the regulator quit working or? It seems that once I change the regulator the truck start normally but after extended driving it reverts back to hesitating and actually not starting.
FYI, the following components have been replaced with this problem:
ECM, ignition module, cap, rotor, wires, plugs, coil and fuel pressure regulator (three times). Fuel pressure at the rail is 59 psi.
Any help would be greatly appreciated, thanks, Rich
Problem resolved! After the third fuel pressure regulator (warranty exchange) I ended up replacing the fuel injection spider. After everything I did, prior to the spider, the fuel pressure regulators would allow the vehicle to run. I got four days on the first, then it went downhill from there. This is the second fuel system spider I've changed in the thirteen years I've had the truck. The first one went out around 100K and this one bit the dust at 190K. Anyway, the truck runs good (knock on wood) now so all I can say is I hope my situation helps others.
actionpaintball
Jul 14, 2006 07:53 PM
apekim
Jun 30, 2006 10:38 AM
