95 Blazer, A/C on causing odd rhythmic loss of power
Old Jul 18, 2011 | 11:34 PM
btmbass's Avatar
btmbass is on a distinguished road
Default 95 Blazer, A/C on causing odd rhythmic loss of power
Hey Guys!
I've got something odd going on with my 95 blazer when I have the A/C on. While accelerating the RPMs will drop by about 200-300 every 3-5 seconds. Idling seems to be ok, its only on acceleration and only when the A/C is on.
Old Jul 19, 2011 | 03:41 AM
BlackBastard's Avatar
BlackBastard is on a distinguished road
its because your A/C uses a compressor.
your compressor is turned by your belt on the front of your engine.
while your A/C is off it is able to rotate freely causing no drag on your engine.
but when you turn you A/C on, the compressors "clutch" kicks in, which puts a load on your engine.
its totally normal so dont worry.
Old Jul 19, 2011 | 04:48 AM
kristoph30's Avatar
kristoph30 is on a distinguished road
It shouldnt cycle that quickly. It is actually something to worry about. Chances are the refrigerant charge is low and the low pressure switch is shutting the compressor down when the pressure gets too low. Cycling that quickly will cause the clutch to fail prematurely. It wont harm the engine but the compressor is paying the price.
Old Jul 19, 2011 | 11:41 PM
very true.
didnt really think about the 3-5 seconds he said.
normal one should cycle about every 15 seconds or so.
Mr Mackey
Jun 28, 2013 07:13 PM
bryanmine
May 19, 2011 11:27 AM
saxman_IN
Jan 7, 2011 01:26 AM
BrianSw
73
Sep 6, 2009 09:16 PM
vatoDETH
Dec 26, 2008 12:04 PM
