95 Blazer code P1345
Old Mar 9, 2011 | 07:03 PM
air1force1's Avatar
air1force1 is on a distinguished road
Default 95 Blazer code P1345
I have a 95 blazer with a code that i have not been able to clear. Where do I post for advice?
Old Mar 9, 2011 | 08:46 PM
rriddle3's Avatar
Start here:
P1345 Explained
Come back to this thread if you have more questions.
Old Mar 12, 2011 | 12:42 PM
air1force1's Avatar
Originally Posted by rriddle3
Start here:
P1345 Explained
UPDATE! I checked the timing (top to bottom) and found it was off 1 or 2 teeth. The rotor did not line up with the mark on the base of the dist when the bottom was on #1 TDC. I pulled the dist. and found the reluctor was bent and rubbing the cam sensor!
I had it in the shop recently and was charged to have this sensor changed. could the the reluctor rubbing in the sensor as it passes cause this P1345 code?
I have ordered the dist, and it will come with a new cam sensor on it. Hope this fixes the surging and the code....Any thoughts?
Old Mar 22, 2011 | 07:26 PM
air1force1's Avatar
Fixed! Replaced the dist. Runs great! Thanks to all who offered advice.
JW
Nutty 99 Blazer
Sep 11, 2017 01:45 PM
tim68
Feb 1, 2011 08:39 AM
96Ls4Dr
Jan 3, 2008 09:03 PM
4x4willywill
Dec 23, 2007 04:33 PM
Mr Blazer LT
Jan 17, 2007 11:25 PM
