95 Blazer Motor locked - Options?
Old Mar 13, 2010 | 01:25 PM
GNRFreak69's Avatar
GNRFreak69 is on a distinguished road
Default 95 Blazer Motor locked - Options?
I have been looking for an engine for my 1995 blazer 4wd 4 door. I can find engines from about every year other than the 95.
What are my options if I can't find a 95 engine?
Lets say I find a 97 engine. X or W or whatever. Can I get away with this as long as I change oilpan/oil pump/pickup tube and intake or are there other differences? I don't mind changing over parts to make it work, I just want to go the easiest route with as little work as possible.
Any recommendations on what to do here?
Old Mar 13, 2010 | 02:20 PM
Going a few years older would be a drop in option for the most part. Going even 1 year newer would require you to replace everything but the short block (block, pistons, crank).
95 is a tough year for sure. So many single year intricacies.
Old Mar 13, 2010 | 03:11 PM
Spectreblazer's Avatar
Banned
Spectreblazer is on a distinguished road
i don't know what cost you're working with but i thought i throw this out there.
in autorv they have a 5.7L listed for 1800 bucks.
i've seen a few blazers converted for v8 in the 2nd gens.
not even sure if it would work in a 95 but i thought it would be another option to consider because a new 4.3L was around 3500, so up front a v8 would be cheaper but im unsure of the modifcations that would be required.
Old Mar 14, 2010 | 11:39 AM
GNRFreak69's Avatar
Thanks for the replies.
So going with an older engine would be easier in my case? What years should I look for, say 91-94? I'm not familiar at all with the engine specs for different years. I know my engine is a W.
Old Mar 14, 2010 | 12:29 PM
Sadchevy's Avatar
Sadchevy is on a distinguished road
in my opinion (which probably dont count for much ) ......have you looked into a rebuilt short block replacement? then take what you need off your original .
Old Mar 19, 2010 | 09:48 PM
GNRFreak69's Avatar
I found a 1995 S10 with low miles, and I can hear it run. Going to go look at it tomorrow. I'm hoping this will work. I will probably have to change the oil pan I think, since it's a 2wd going into a 4wd. Anything else I should look out for? Someone said something about looking at where the plug wires come up at???
Chic_Bowdrie
Mar 12, 2012 03:30 PM
hbnr86
Dec 29, 2008 08:40 PM
countryguy1713
Sep 3, 2008 11:08 AM
LadyNightHawk12
Oct 23, 2007 02:10 AM
michellesmark01
Engine & Internal
Jan 21, 2006 07:30 AM
