95 blazer no purge flow detected
Old Jul 18, 2015 | 06:46 PM
bam_9_9_9's Avatar
bam_9_9_9 is on a distinguished road
Default 95 blazer no purge flow detected
po441 no purge flow detected.
4.3l vortec. vin w. cpi motor.
ive replaced the purge solenoid. cause when supplied 12v it did not click and you couldn't blow through it. the new solenoid tests good. new gas tank vent valve, since it was busted off.
I blew through the line at the evap solenoid and had somebody listen at the gas tank while cap was open and you can hear hissing. so the lines aren't clogged. there was some resistance when I blew through it though. that was before I replaced the one of the gas tank vent valves that was busted and capped off. so now I might have better flow. haven't tried it again.
the solenoid gets 12v when key on.
my question is what does the one sensor behind the evap solenoid do? ive looked it up and its called the evap vacuum switch or something like that. im wondering if that's what actually detecting the flow and that it failed and cant detect any flow. thus spitting out this code. how do I test this sensor before I buy a new one?
thanks
Old Jul 21, 2015 | 05:54 PM
bam_9_9_9's Avatar
so anybody have an idea what that sensor actually does. ive looked through it and you can see through it, it has little lines or bars going side to side in different directions.
does this thing act as a mass airflow sensor or is it like a pressure switch.
Old Jul 21, 2015 | 06:29 PM
Post an image of it, that might help.
Old Jul 22, 2015 | 02:42 PM
bam_9_9_9's Avatar
Old Jul 22, 2015 | 02:43 PM
bam_9_9_9's Avatar
its the one to the right of the oil fill tube
Old Jul 24, 2015 | 01:33 PM
bam_9_9_9's Avatar
so can anybody tell me what that sensor does, and how to test it.
im going to blow out the lines with compressed air to see if that helps. and if the evap box can be taken apart without being destroyed then I might clean that out too.
Old Sep 10, 2015 | 02:22 AM
bam_9_9_9's Avatar
any ideas?
Old Jan 30, 2016 | 03:05 PM
tekflight's Avatar
tekflight is on a distinguished road
thanks
Probably long answered but The sensor tells the computer that you have flow/vac for the vent system. If it sees nothing, you get that infamous code 441.
Old Jan 30, 2016 | 10:42 PM
bam_9_9_9's Avatar
I have actually fixed this problem. I rebuilt the evap canister. and the code never came back. I cut it open replaced the filters and the activated carbon and then sealed it back up. heres a video I made.
Old May 10, 2020 | 01:01 PM
Badboyizda1's Avatar
Badboyizda1 is on a distinguished road
Default O2 sensor
I changed my idle control valve on my ,98 and when done started truck and it revved so high thought it would blow up. Shut it down and manually adjusted throttle. BAD mistake cuz they adjust themselves and mine hasn't been the same since. I trying taking off the throttle body and cleaning it up first to no avail. Just change tcs valve and hope it works. Bank 1 is driver side. Sensor 1 is on manifold and 3 is past cat. Bank 2 and 4 is the opposite
joejiz
36
Apr 10, 2016 03:52 PM
marine
Jan 28, 2010 07:04 PM
daniel010
Feb 2, 2009 06:50 AM
nflea7
Aug 27, 2007 01:29 PM
sonicdrft
Nitrous, Super Chargers, & Turbos
Sep 17, 2006 04:35 PM
