95 Blazer rear hatch glass squeaky
Old Sep 4, 2018 | 01:50 PM
Matthew Anglin's Avatar
Matthew Anglin is on a distinguished road
Default 95 Blazer rear hatch glass squeaky
anyone know how to fix the squeaking of the hatch glass it is driving me crazy squeaks non stop while driving
Old Sep 5, 2018 | 04:37 AM
GreenBlazer2002's Avatar
what type of rear hatch do you have? Drop gate or lift gate?
Old Sep 5, 2018 | 03:41 PM
Mine is the lift glass then drop tail gate, I thought all the blazers was like that I didn't know they had the full hatch in those years, I have owned 3 blazers a 92, 94 and this one a 95 and all 3 squeaked bad on the back glass hatch, I thought about replacing the glass seal and the tail gate seal and see if that helped but I didn't know so I asked on here 1st to see what others did to stop it from squeaking
Old Sep 5, 2018 | 04:47 PM
On mine, I put some material behind those rubber bump stops that the gate rests against when its closed to keep it snug. Then I took the handle/latch off the glass and put some foam rubber material between it and the glass, then reinstalled it. Haven't heard from it since.
Old Sep 5, 2018 | 06:11 PM
I have a lift gate model and noticed that the hinge pins for the glass when moved so that the heads are against the hinge the squeakiness is reduced. For some reason to work out. I should probably try to keep them in place with zip-ties around the pins.
Old Sep 8, 2018 | 06:27 AM
I'll post a pic on what helps on mine. Just ran out of black tape the last time it needed some attention.
A bit of grease on the locking "U" and the centering finger also helps.
CraigSnedeker
Jul 11, 2012 09:38 PM
Jace1217
Feb 22, 2012 03:55 AM
rntbuck
Aug 15, 2011 03:40 PM
michaeljwyo
Sep 29, 2009 11:31 AM
