95 blazer stuck in 4lo
Old Mar 2, 2009 | 03:26 PM
matthew81's Avatar
matthew81 is an unknown quantity at this point
Default 95 blazer stuck in 4lo
95 blazer stuck in4 low and keep blowing 4wd fuse when i put the transmission in nuetral to switch it out of 4lo the problem is i change the harness for the 3 button switch on the dash the wires where loose then i fried the tccm in the dash and changed that with a 97 jimmy one i dont know if theres a difference in the two but i really need help i did the codes check and got code 1 then cleared it the tried it again now got code 3 dont know what to do
Old Mar 2, 2009 | 03:30 PM
Default RE: 95 blazer stuck in 4lo
Were the PNs even close between the two? Did the 97 Jimmy have a 3 button switch?
Look at the Tech Article (DIY) post for "OBD2 Non-Automatic Transfer Case Diagnostics" for a code description.
Old Mar 2, 2009 | 03:46 PM
matthew81's Avatar
yeah it plugged right in the harness for the tccm but it doesnt click unless its in nuetral and then blows the fuse for 4wd but all the other fuses are fine
Old Mar 2, 2009 | 03:47 PM
matthew81's Avatar
whatsis the positive voltage circuit ckt 1640
Shelby
Feb 25, 2011 07:42 PM
dallas27
Dec 12, 2009 09:55 PM
ejp
Jan 4, 2009 02:47 PM
Alterac
Aug 25, 2008 08:48 PM
FImports
May 30, 2007 09:57 PM
