95 CPI SPIDER: Fuel puddle in plenum no spider leaks??HELP
Old May 1, 2014 | 08:06 PM
  #31
spittybays
Guest
Posts: n/a
What do you have going on exactly?
Old May 2, 2014 | 05:50 AM
  #32
TennesseeBoy's Avatar
TennesseeBoy is on a distinguished road
replaced nut kit, spider, and another pressure regulator on top of that. still getting fuel pooling in plenum and gas smell. not major, but enough to notice. gas mileage is only down a little at 17.5, and still a small catch in the idle. every time I open it up and clean it out and replace the plugs it runs great for a week, then starts again. I know this has been beat to death, but I can't find the leak for nothing!
Old May 2, 2014 | 03:24 PM
  #33
spittybays
Guest
Posts: n/a
My mind is going, on that fpr is there a gasket, are there one or two hold downs , if two could one be cross threaded , making an angle and a leak. Sorry haven't been in mine for about two years. Seem to remember a safety torx someplace in there.....
Old May 2, 2014 | 04:56 PM
  #34
Thanks, I'm open to anything right now. I'm gonna tear back into it and make sure everything is tight, straight, and coupled good. Hopefully that will work.
Old Jan 18, 2015 | 12:36 AM
  #35
jrrybrwn's Avatar
jrrybrwn is on a distinguished road
Are you 100% sure its fuel and not trans fluid being sucked from transfer case? Doesn't explain fuel smell but I chased a similar problem and found a bad seal letting trans fluid into t-case and getting sucked into intake via vacuum.
just a thought.
Old May 16, 2024 | 09:01 PM
  #36
Diky's Avatar
Diky is on a distinguished road
Default 95 spider injector.
Originally Posted by hunter05
I should state that he did find a problem with the new regulator, it wasnt blowing off until 100 psi. I took it back he rechecked and injector passed all the tests. I will check in the plenum for fuel/antifreeze after a few days for driving.
95 spiderI need the clip that holds the two hoses on n place. Can anyone help?
CCBlocker
Aug 19, 2014 07:07 PM
hunter05
Mar 29, 2014 11:32 AM
Klturi421
13
Mar 19, 2013 07:19 PM
drperry
Jun 26, 2007 02:44 PM
PER10DER
Engine & Internal
Sep 6, 2006 02:16 AM
