95 door panel pocket
This is the final solution to crappy 95 door panel storage pockets. No more glue, epoxy or trying to be careful so you don't knock it off again. It's permanent now !!!!!!!!!!! you can also still remove the panel as a unit, in other words, the pocket is attached to the panel and not the door, so removal of the panel is same. NO screws running through panel and everything and into the metal of the door.
Brian5792
08-28-2013 08:16 PM
