95 Rear Driver side Brake wheel cylinder wrench size (Canada)
Old Sep 4, 2013 | 08:31 PM
wookard's Avatar
wookard is on a distinguished road
Default 95 Rear Driver side Brake wheel cylinder wrench size (Canada)
I want to get the correct tool to remove the brake wheel cylinder from my 95 Blazer and I am unsure of the correct size and whether it is metric or SAE.
Thanks for any help,
I currently have a bottle of brake fluid, oil pan, socket set and I can get the brake wheel cylinder at the Auto store across from me.
Old Sep 4, 2013 | 08:44 PM
burned's Avatar
burned is on a distinguished road
Metric.
You're going to need brake tools also
Canadian Tire Brake Tools
Do you have some syl-glide for the backing plate and pins? You want to lube the pivot points.
Old Sep 13, 2013 | 07:30 PM
WitchingHour's Avatar
WitchingHour is an unknown quantity at this point
It's been a while since I did mine... I want to say you'd need a 13mm wrench or socket, but don't quote me on that.
Old Sep 14, 2013 | 03:14 AM
Pewter2002's Avatar
Pewter2002 is on a distinguished road
Just replaced the rear calipers on mine (USA). 13 mm for two caliper bolts, 10 mm for the bleeder.
Old Sep 14, 2013 | 07:53 AM
sky_blazer's Avatar
sky_blazer is on a distinguished road
just speaking from experience dont use a regular wrench get a set of "box wrenches" you will be glad you did not so much for the bolts that secure it to backing plate but the actual brake line. you dont wanna round that off. spray it with PB blaster several times then let it sit overnight. makes life easier
Old Sep 14, 2013 | 02:34 PM
burned's Avatar
He has drum brakes in the rear.
Old Sep 15, 2013 | 05:57 AM
Pewter2002's Avatar
I stand corrected and informed. My apologies.
mamawolf70
Apr 10, 2020 10:44 AM
stjdylsn
Apr 9, 2011 12:58 PM
dacop
Jan 16, 2010 06:12 PM
jcortes63
Oct 26, 2008 03:15 PM
95LS
Jun 13, 2008 02:18 PM
