Big oil leak! help!
Old Sep 10, 2013 | 09:47 PM
fletch125's Avatar
fletch125 is an unknown quantity at this point
Default Big oil leak! help!
So about four weeks ago I began to notice an oil leak in my 02 chevy blazer 2wd v6 4.3l. Its very close to the front bumper. The sway bar is covered with oil as well as parts of the frame and driver side wheel well. Everything is sort of covered in oil from blowback. Im suspecting the oil cooler lines that lead from the oil filter. Does this sound correct? A half dollar size amount leaks out everytime im parked sometimes more and its getting progressivley worse. Im an auto tech student but I dont have time to take it into school. Someone help lol!
Old Sep 10, 2013 | 10:44 PM
Toby Hanson's Avatar
Toby Hanson will become famous soon enough
That sounds about right to me. Take the front skid plate off and inspect the oil filter mount for leakage. Clean all the old oil off with some kind of solvent and then drive it around for a little while until you can see where the oil is coming from. It very well could be from the lines that attach to that filter mount. I changed out the lines on my '98 Jimmy. It's awkward to get the lines attached to the block adapter because of the angle and some of the stuff in the way but it can be done.
Old Sep 11, 2013 | 01:04 AM
LannyL81's Avatar
Remove the skid plate.
Wipe off as much oil as you can from the oil filter adapter, frame, etc.
Start engine and watch under the engine for oil dripping.
Start looking for the leak.
Hopefully it is the oil filter. But get a flashlight and see if the front two oil pan bolts are present or loose. For some reason the front two get loose and fall out.
Check the front cover as well...this is where my '02 is leaking from.
Old Sep 15, 2013 | 12:22 AM
AfterBurn99's Avatar
AfterBurn99 is on a distinguished road
They sell a UV dye and a black light with glasses that you can add to oil. Make sure its for OIL not AC.
remove skid plate, get some brake clean and wash it all down and wipe away till nothing is left. Add the UV dye to the engine oil. Start and run engine, check with the black light and UV glasses. You should see a bright color, green, red, what ever the dye will look like.
Could be a crank seal, could be the oil cooler lines, heck could be as simple as a double gasketed oil filter.
Old Sep 15, 2013 | 11:09 AM
cleburne red's Avatar
If it does turn out to be the oil lines, read up on them on this site. You can build your own that will last much longer than the Dorman replacements, and they will be cheaper as well!
ComputerNerdBD
Mar 20, 2013 12:33 AM
clbychil
Mar 8, 2011 01:35 PM
butters
Sep 29, 2008 06:40 PM
TAZ454
Jan 28, 2008 10:11 AM
2001blazer
Tires and Wheels
Mar 9, 2006 02:39 PM
