95 S-10 Blazer Fuel Injector and inlet line replacement
Old Aug 22, 2009 | 10:57 AM
TexMech's Avatar
TexMech is on a distinguished road
Default 95 S-10 Blazer Fuel Injector and inlet line replacement
I'm a new member and need help. I have replaced the spider fuel injector on my 1995 Blazer and when I turned the key to the on position to check for leaks, I found a pin hole leak in the fuel line. How do I replace this thing? Reading some of the other posts I saw reference to a nut kit... what is that?
Old Aug 22, 2009 | 01:09 PM
mchap87's Avatar
mchap87 is on a distinguished road
the nut kit refers to the two internal fuel lines that sit next to the spider. If you do a search on this site you can get more info. i just replaced mine about a month a go. good luck.
Old Aug 22, 2009 | 01:50 PM
reelbroke2's Avatar
reelbroke2 is on a distinguished road
Is your fuel leak internal under the plenum or are you talkin about the metal fuel lines going into the intake?
Old Aug 24, 2009 | 05:15 PM
TexMech's Avatar
The leaking fuel line is internal and connects to the spider injector.
Old Aug 24, 2009 | 05:18 PM
reelbroke2's Avatar
you can get the fuel return lines, aka nut kit, from advance for around 40 bucks and is rather simple to change.
Old Aug 24, 2009 | 08:10 PM
x2
rocknroadie
Sep 2, 2010 07:19 PM
rcravincase
Jun 6, 2010 09:29 AM
<3blazer
Headers, Intake, & Exhaust
Jul 13, 2009 11:09 PM
ncmudblazer
Jun 5, 2008 03:50 PM
burak sozer
Jun 4, 2008 02:05 AM
