96 blazer 4.3 no power
Old 06-08-2018, 11:36 PM
Nlehman50317's Avatar
Nlehman50317 is on a distinguished road
Default 96 blazer 4.3 no power
I couldn't go above 10mph so I knocked out my clogged catalytic converter and now sometimes it will barely take off it will bog down real bad. But if u floor it it falls on its face need help badly
Old 06-09-2018, 08:37 AM
GeorgeLG's Avatar
GeorgeLG will become famous soon enough
How do you know that you had a clogged converter?
What do you mean by knocked it out?
Do you have any codes?
George
Old 06-10-2018, 07:07 PM
George
I had it tested and the shop said it was clogged so I drilled out the center and now it barely takes off sometimes and if u floor it it will bog out bad
Old 06-11-2018, 02:14 AM
Mike.308's Avatar
Clogged converter seems to be a result, not the main reason to me. It could be leaking injector, dead O2 sensor or anything else.
I would start with connecting a dongle and checking the ST/FT fuel trims.
Old 06-11-2018, 07:43 AM
Tajohns34's Avatar
Are you getting a check engine light? I had similar symptoms before when my crank position sensor went bad.
Old 06-11-2018, 07:52 AM
My problem is that I have no check engine light on ethier
Old 06-11-2018, 08:00 AM
man0steel's Avatar
man0steel is on a distinguished road
You very well may have a chunk of the converter floating around in your exhaust system somewhere. Did you remove everything from the cat or just bore a hole thru it. A loose chunk can cause an intermittent issue. Check the muffler and pipe between the two.
Old 06-11-2018, 08:51 AM
I knocked everything out
Old 06-11-2018, 09:18 AM
man0steel's Avatar
Any of the debris look melted?
Old 06-11-2018, 09:28 AM
Yeah it did
Quick Reply: 96 blazer 4.3 no power
