96 blazer console lights
Old Jul 19, 2010 | 07:39 PM
justdave689's Avatar
justdave689 is on a distinguished road
Default 96 blazer console lights
hey all, I have a 96 Blazer with a 5 speed manual tranny with manual 4WD shifter.
i just had a new slave cylinder installed in the tranny for the clutch and new clutch installed.
all works great except i have lost all the lights in the center console where it shows if you are in 2WD , 4WD high, 4WD low etc.
the only light that works is the small square light in the center at the 4WD high , Neutral and 4WD Low.
before i take it back is there something that i could check and see if its just something they left unplugged?
i took the console apart and the board with the lights on it looks fine, all the little lights still have an intact filament.
i unplugged and reconnected the connectors on both ends of the board.
per the manual the same fuse is also for the dash lights and they all work fine.
i found one wire assembly plugged into the transfer case, unplugged and reconnected and didnt help it any.
any other connector that might have got pulled on that i could check?
any other ideas?
please advise
Thank You!
Riggins Brian
Aug 10, 2014 01:27 PM
edavison
Dec 20, 2010 09:55 PM
BrianMichaels1
Oct 8, 2008 04:52 PM
deck101
Oct 5, 2008 09:52 AM
nelson85
Jun 22, 2006 07:39 PM
