96 Blazer keeps setting these 2 codes P0122 and P1122
Old Sep 29, 2009 | 12:21 PM
taguy94's Avatar
taguy94 is on a distinguished road
Default 96 Blazer keeps setting these 2 codes P0122 and P1122
I sold a friend of mine a blazer that just before he bought it I replaced the TPS now he has these two codes that keep coming back.
He also replaced the TPS thinking that the other one was defective but still there he has cleared the codes and it still keeps coming up.
Once in a while it will start missing and cutting out and then die,, you can restart and runs fine for another 40-50 miles and then same thing again
Any experience with this???
He also did the cam sensor
2 O2 sensors
Old Sep 29, 2009 | 12:27 PM
Start here:
P0122 - Throttle Position Sensor Circuit Low Voltage
P1122 - TP Sensor Circuit Intermittent Low Voltage
Then make sure that you are getting +5V on the reference wire to the TPS sensor, a good ground on the ground wire, and that you have good continuity on the sensor return to the PCM.
jojocarreno
May 27, 2011 12:27 PM
HoleinOne350
Apr 6, 2011 10:40 PM
bc4059
Aug 4, 2010 08:36 PM
Spinman
Aug 20, 2008 02:39 PM
bbunn1
Sep 1, 2006 12:55 AM
