96 blazer no start engine cranks then backfires
Old Jul 15, 2012 | 04:45 PM
jbb421's Avatar
jbb421 is on a distinguished road
Default 96 blazer no start engine cranks then backfires
I bought this blazer with 262k on it from my dad replaced the plugs wires dcap/rotor button, and the dist gear. it ran great for about 2 weeks parked it one night went to start it and it would crank for about two seconds then the starter would bog really bad and crank easily again and do the same over and over. went and got a new fuel filter hoping that was it and not timing chain etc the fuel filter was foobered black fuel/white came out of it so i thought awesome tried to crank it and now all it does is spin spin spin then backfires. My dad bought this truck brand new in 96 and it has never had a starting issue other than the d cap arcing out(bad dist gear) and a bad fuel pump... it sat for almost 2 years once and it cranked right up on the first try so... this issue really made me go wtf lol. I'm thinking it might be the timing chain but then again i dont think it is because it ran perfectly fine before i parked it.
Thanks jbb sorry for the bad grammar
Old Jul 15, 2012 | 06:40 PM
50lb_cat's Avatar
are any codes coming up? Any black smoke out the tailpipe? I would start with a fuel pressure and leakdown test. Key on egine off, should be about 60 to 65 and shouldn't go below 55 for 10 minutes.
Old Jul 15, 2012 | 09:43 PM
What brand distributor cap & rotor did you install? If it was something other than AC Delco, that's most likely the problem. 2 weeks is about right for some of the aftermarket brands
Old Jul 16, 2012 | 02:28 AM
jbb421's Avatar
so i went and tried to crank it again for troubleshooting and it bucked and kicked and then ran fine.... ive and 1/4 tank through it since then and it running like she always has.... not getting gas at the gas station down the road again... ill just have to go to town for bp or shell.... whats the best fuel system cleaner to run?
Thanks for the input sorry for making a thread after not trying agian :P
Old Jul 16, 2012 | 03:08 AM
50lb_cat's Avatar
I use techron concentrate at every oil change. Glad it's running good for you again
kwbond
Mar 18, 2014 12:39 AM
bobert84
Aug 14, 2012 03:47 PM
bsbob
Jul 22, 2011 12:48 PM
mmem700
Jul 21, 2009 07:41 AM
nyjeepman
34
Mar 15, 2009 07:40 PM
