96 blazer sputters when first put in gear
Old May 19, 2014 | 09:17 AM
Mikeman84's Avatar
Mikeman84 is on a distinguished road
Default 96 blazer sputters when first put in gear
I have a 96 4x4 blazer that when I first go out in the morning to go to work it starts up fine an idles good but as soon as I put it in gear an give it gas it hesitates an sputters for a second like its going to stall than goes away an it dosent happen again unless it sits fir a long period of time like over nite. Does anyone have any idea what would be causing that.
Old May 19, 2014 | 02:17 PM
Lancealot's Avatar
Lancealot is on a distinguished road
Carbon build up on the idle air control valve could be causing it to stick a bit after sitting. When the idle drops from putting it in gear the iac valve should open a little to allow more air and increase your idle back to normal. Should be pretty smooth and seamless. Can you get the same results in the morning by turning on the air conditioner instead of putting it in gear? If ac doesn't work this won't change idle.
Abutera76
Jan 7, 2011 12:48 AM
rob1621
Mar 21, 2008 01:23 PM
Big L
Mar 14, 2008 12:25 PM
clay1937
Oct 28, 2007 10:44 AM
themckeown
Oct 22, 2007 01:11 AM
