96 blazer wont start has good spark and fuel
Last saturday i was driving home, and my 96 blazer randomly died check engine light went on and then wouldnt start back up it only cranks and cranks
had towed home.
tested had low fuel pressure around 30 psi
put fuel pump in then had good fuel pressure around 50 psi
still cranks only so then i found my distributor mounting ears were cracked so i ordered a distributor rotor and cap
timed and installed same thing cranks only
i found the old distibutor teeth were worn and damaged so i thought that was the problem but turns out it still doesnt start so then in the mean time from cranking so much i killed the starter. so i replaced that too.
I am without a vehicle going on about a week.
cant figure out problem
I have spark i have fuel and i believe the timing is correct too. The fuel pressure stays high i left gauge on for a while.
Oh and this started on my week off !!!!
had towed home.
What exactly are your fuel pressure numbers? to start it needs to be 60+ psi. did you have the codes read?? if so what were they. Are you positive you have good spark?
Edit: Take a look through This Thread on the same issue, see if anything helps
toolshed59
22
01-15-2014 06:58 PM
armydad71
05-03-2010 01:48 PM
fast400
08-31-2007 05:07 PM
