96 fuel pressure help
Old Aug 7, 2010 | 07:44 PM
steveiowa1's Avatar
steveiowa1 is on a distinguished road
Default 96 fuel pressure help
I have fuel pressure problem. It loses pressure when it sits for a couple hours. I have looked for leaks none. I thought it was check valve fuel pump was replaced 2 years ago. Bought a fuel pressure regulator but don't know where it is or how to replace. I think is under the thottle body but there are 2 fuel lines going in and recteangular wire block that won't come loose. What I do to get it started is run the fuel pump with the key to on and off and back on 7 times to get pressure up then it starts.Any help with this problem or telling me I'm fishing the problem would be greatly appericated. Steve
Old Aug 7, 2010 | 09:40 PM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
You have tto pull the upper plenum to get at the FPR. It sits in the middle and costs about $50.00. When you get to it post back and I can give you some tips so you only have to do it once.
Old Aug 8, 2010 | 12:27 PM
rriddle3's Avatar
Completly work through the steps in this post - 96+ Fuel System Diagnosis - and you will trace down the source of the problem. Beats throwing parts at it.
brianroark
Jun 25, 2010 03:14 PM
Spartan66
Jul 11, 2008 02:34 PM
riverjamie
Sep 24, 2007 08:21 PM
aspenpup
Sep 9, 2007 07:11 PM
jlinder
Aug 21, 2005 11:08 AM
