97 blazer #3 fuse blows
My #3 fuse keeps blowing when i turn on the headlight switch
1/17/11 short is on headlight switch, headlights will stay on, parking lights and dash lights are out 4wd drive switch out too but works before i turn on headlight switch then fuse blows ???
See if this description of what is on Fuse #3 helps.
Mark K
Mark K
Were there any additional gizmos or accessories added recently? If not, try replacing the headlight switch? Are you sure that's where the short is? Just because you blow the #3 fuse when you hit the light switch, doesn't point only to that circuit or switch necessarily. Try connecting a test light to the #3 circuit at the fuse panel and then pull/replace fuses one by one till the test light calms down/dims. When this happens, you have found the circuit that the #3 circuit has been shorted to. Then when you look at the schematics, it should be much easier to fix.
How did you make out with this so far?
A.
A.
Have schematics hard to follow backup lights work and so does the brake lights after the fuse blows high beam and low also work. maybe not the light switch .the park lights are out dash lights out number plate light out. ????
I can't recall the number of the fuse, but check the park lamp fuse. This fuse also controls the BCM (Body Control Module) and if this fuse is blown, it will cause the headlamps to do all sorts of weird things, possibly overloading them and then causing THAT (Fuse 3) to blow.
I don't think we ever established whether or not any aftermarket electronics were installed or behind-dash repairs were done? Has there been any modifications with reference to cutting, splicing, scotchlock connects, etc?
Thanks!
A.
Thanks!
A.
replaced plate light blown out all is fine now
ncpi
10-12-2011 09:17 PM
DREWZBOY
04-08-2010 11:50 PM
skybolt31
11-29-2009 03:10 PM
