97 Blazer ABS NOT working
Old Dec 21, 2011 | 01:04 PM
SoullessNihilist's Avatar
SoullessNihilist is on a distinguished road
the scan tool said all of the sensors where bad, so i'm thinking the module is dead. yes i have good brake pressure.
Old Dec 21, 2011 | 01:08 PM
Testing the sensors will tell you whether it's a bad module or not. The sensors should read >250mV-AC when you spin the wheel with a multimeter set to read AC voltage probing the pins in the connector to the speed sensor.
Old Dec 24, 2011 | 12:37 PM
i'll check'em out as soon as i can find the time!
Old Jan 19, 2012 | 11:20 PM
tattooed&screwed's Avatar
tattooed&screwed is on a distinguished road
i just changed out my rear brake line on my 97 blazer and can not get the ABS to bleed the rear brakes but will bleed the front brakes. I tookjoff the brake lines off the abs and no fluid will come out the line for the rear brakes. the brake light is on but not the abs light. what is going on, can the portioning valve be moved or do i have to replace the whole abs unit?
Old Jan 20, 2012 | 12:03 AM
pettyfog's Avatar
Read this thread:
https://blazerforum.com/forum/2nd-ge...r-w-abs-64701/
I just disconnected the battery for about 1/2 hour to reset the internal proportioning valve as suggested in one thread - we'll see how that goes today.
That may help
Old Jan 20, 2012 | 10:04 AM
Tedtrejo11's Avatar
Tedtrejo11 is on a distinguished road
Hey guys I own a 2001 blazer and I'm having a few problems with it and was wondering if talk can help.
1st: my gas meter is like really weird it doesn't function right does anyone know whY could it be?
2nd: my windshield wiped fluid is not working as well WT could it be?
3rd: does anyone suggest what I could do to make my blazer run smooth like any suggestions I would apreciate it.
Old Jan 20, 2012 | 11:05 AM
pettyfog's Avatar
So.. check if I got this straight. Your problems have nothing to do with ABS.. and YET..
Old Jan 20, 2012 | 01:13 PM
i decided not to check my ABS sensors yet because it's too crappy outside. but the pattern i've picked up is... when i actually need my ABS, like when there is snow or ice on the road, It works. and when the roads are dry the light comes on. so i'm thinking the 31" tires are probably to blame. we'll see what happens when i get some 33's under it!!
Old Feb 7, 2012 | 09:01 PM
Pettyfog, thank you very much for your advice! I disconnected my battery and that worked for reseting the proportioning valve and the brakes bleed perfectly. Thanks again.
big_charms@hotmail.com
Mar 20, 2014 10:26 PM
mjw1991
Feb 24, 2013 10:18 PM
97BlazerMama
Aug 19, 2011 08:18 PM
max1995
Dec 6, 2010 08:24 PM
cyberdog
Feb 3, 2010 02:04 PM
