97 Blazer won't start Sounds like timing.
Old Feb 18, 2015 | 10:46 AM
RodneyB's Avatar
RodneyB is on a distinguished road
Default Problem fixed
Here is the story. My daughter was headed to school and the blazer died. She said nothing crazy just died. I knew I had a problem with the fuel system so I started there. Had to replace the spider assym. I did upgrade it to the newer style. Pressures are holding now so I think that problem is solved. Now when I try and start it, it sounds like it is dragging. You can also hear it try and backfire. Sounds like a timing problem but I don't know for sure.
Old Feb 18, 2015 | 06:15 PM
Gregg64's Avatar
Gregg64 is on a distinguished road
There is most likely a code on the memory that may give you some clues and us more info. Take it somewhere where they can read them for you. Many places will do this for free.
Old Feb 18, 2015 | 06:28 PM
Did you remove the distributor, (or any of the plug wires) when replacing the injector assembly?
gmaltese
Aug 29, 2013 06:25 PM
lecktrix
Apr 2, 2012 10:48 PM
rraasch04
Aug 8, 2009 09:20 AM
SuperBlazer
14
Mar 3, 2009 07:46 PM
camohog1
Jan 24, 2006 07:46 PM
