97 fuel pump issues
Old 11-25-2011 | 05:55 PM
psychomike418's Avatar
psychomike418 is on a distinguished road
Default 97 fuel pump issues
help please!can anyone tell me if there is an aftermarket fuel pump i can use instead of replacing the assembly(can i change just the pump?)? its a 97 4dr 4wd. any info would be great!!!!!
Old 11-25-2011 | 06:52 PM
There are kits available that are just the fuel pump, but this is an area where many have skimped and ended up repeating the repair in short order. You could try to find a true AC Delco pump only on eBay if you really can't afford an AC Delco or Delphi complete replacement unit, but before doing so, I would check the electrical connection at the top of the pump assembly. They like to overheat and melt and if that is the case, you should replace the entire unit.
Old 11-25-2011 | 08:05 PM
thanks for the help. the connection on the pump is good, and the pump is growling when it does run. This started yesterday afternoon, it started this am, but wouldnt start this afternoon,and ran again tonite. Ive never had a pump do that, usually they run or they dont. are those pumps only available on ebay or can you find them at a parts store?
Old 11-25-2011 | 08:16 PM
After looking up a few of them on eBay, I question whether they actually are AC Delco pumps as there is no valid AC Delco part number listed. You could try contacting one of the sellers to verify the AC Delco part number for the "repair kit" only, not just the pump assembly (with sending unit etc) PN that it is compatible with. Just search on eBay for "1997 Blazer Delco fuel pump"
BouncingRadical
14
11-27-2015 01:30 AM
cide
11-07-2009 02:26 PM
upblazer95
03-08-2009 08:15 PM
Lckyctch
12-30-2007 06:38 PM
mytruck2
12-13-2006 05:50 PM
Quick Reply: 97 fuel pump issues
