97 Will not start
Old Apr 9, 2014 | 12:52 PM
jannes_z-28's Avatar
jannes_z-28 is on a distinguished road
Default 97 Will not start
I have a 97 S10 Blazer that is dead and will not start. Problem happened suddenly, it started OK and when going how it didn't start. Had to tow it back.
I have checked the ignition and it didn't give a spark. I changed the Ignition module and the Coil. But it still wouldn't start. It cranks and you get a smell of fuel. At the schrader I have gas and it is under pressure. I can hear the fuelpump running when ignition is turned on.
I have no codes on the ODBC reader.
I am lost...
What can be wrong and what should I check next?
Thanks
Jan
Old Apr 9, 2014 | 01:33 PM
jpimp's Avatar
jpimp is on a distinguished road
What is the fuel pressure?...you need a certain amount to start.
Do you have spark at the coil wire before the distributor cap?
Do the fuses check out OK?
Edit: this is all assuming that you crank but don't fire?
Old Apr 9, 2014 | 02:14 PM
Yes it cranks but will not fire.
I haven't measured the fuel pressure. But squezes with force when I press the schrader valve. I know that doesn't mean that the pressure is OK.
I have checked the spark with a Strobelight and it will not light up. No other checks on spark but I assume that this shows that it has no spark.
I can check more about the spark on friday. Iäll have to go on a trip tomorrow and will be back late.
When ignition is turned on the fuelpump runs for a few seconds and then shuts off, that is normal. When cranking it smells a lot of fuel so I assume that it will get fuel properly.
Jan
Jan
Old Apr 9, 2014 | 04:38 PM
spittybays
Guest
Posts: n/a
Wow there's a bunch of stuff too check depending on how fast you need the vehicle.
Out of the woods and need it fast that its a 97, I would try to get an ignition switch.
Jan, have no idea if you have any Junkers around but in todays market world one in a couple of days would not be unreasonable.
stschuyler25
Nov 21, 2010 09:34 AM
wayland
Dec 9, 2009 12:38 PM
blazerJim1701
Jul 26, 2009 09:18 PM
actionpaintball
Jul 14, 2006 07:53 PM
