98 4WD issues
Old Jan 13, 2015 | 10:46 AM
Blazerman47's Avatar
Blazerman47 is on a distinguished road
Default 98 4WD issues
I have a 98. My 4x4 quit working. Found a vacuum line cut, replaced it , the switch on the transfer case and actuator under battery is new, cable is not frozen. I put an OBDI II and got codes for wheel speed signal missing on the front wheels. Got a CO237 for eradict rear speed sensor. Went to check transfer case, got link connect error. What do I check next? I know I have no floor heat. But I did have 4x4 at that time.
Old Jan 13, 2015 | 02:19 PM
LannyL81's Avatar
Need more info: 3 or 4 button 4x4 switch; is T-case switching into 4wd...can you hear/feel it?; what are the 4x4 switch button lites doing?
Why was the vacuum T-case switch replaced?
Were all the other vacuum lines connected?
Have you checked for vacuum?
Cleaned the front speed sensor?
I belive to access T-case link requires more than normal OBDII code reader.
Old Jan 13, 2015 | 04:49 PM
Which link connect error did you get? What was the code?
daemeon2
Jan 6, 2013 04:06 PM
99slobra
Jan 3, 2013 05:02 PM
cruukedeye
Jun 4, 2011 06:49 PM
Real420
Nov 25, 2006 05:53 AM
bellert
Jul 14, 2006 01:21 AM
