98 blazer, acts up when AC is on
Old Jun 12, 2014 | 08:39 PM
86sleeper's Avatar
86sleeper is an unknown quantity at this point
Default 98 blazer, acts up when AC is on
We could drive the truck all day with no problems, then we turn the AC on and sometime after the truck hesitates and spudders, codes p0300 and p0108 kicks in. Last summer I put in new plugs, wires, cap , rotor, coil, module, maf, spider, ecm, distributor, egr, iac and tps. Truck had been running nice and in the past few months she started again, I was pulling my hair until I notice that she acts up only when the AC is on. Help will be highly appreciated. The florida heat is a killer. Thank you guys in advanced.
Old Jun 13, 2014 | 07:53 AM
canuck blazer's Avatar
canuck blazer is on a distinguished road
I will assume you used Delco ignition parts wire plugs cap and rotor and say I would look at the map sensor as the problem
Old Jun 13, 2014 | 08:37 PM
86sleeper's Avatar
I put 2 new map sensors, and changed the pigtail. The map sensors were not delco, they were from carquest.
Old Jun 13, 2014 | 10:43 PM
spittybays
Guest
Posts: n/a
only Ac AFTER ac is unplugged codes are cleared You still blow codes. Check wiring on ac compressor,
Old Jun 14, 2014 | 12:39 AM
Blazer_4x4's Avatar
Blazer_4x4 is on a distinguished road
Potential causes of a P0108 code:
  • Bad MAP sensor
  • Leak at MAP sensor rubber gasket
  • Engine vacuum leak
  • Short in signal wire to PCM
  • Short on reference voltage wire from PCM
  • Open in ground circuit to MAP
  • Worn engine causing low vacuum
  • stuck-open EGR Valve
  • defective Idle Air Control Motor or dirty IAC port and or dirty IAC motor plunger, which causes a very low or very high engine idle.
Low idle = Low vacuum, if the idle air control motor isn't operating properly, then when the AC compressor kicks on it could be loading the engine idle speed below minimum operating vacuum pressure.
Just throwing out a few ideas. Hope it helps to locate the source of the problem.
Old Jun 14, 2014 | 11:11 AM
86sleeper's Avatar
I clear the codes, turn the ac off and then she gets back to normal
Old Jun 14, 2014 | 11:14 AM
86sleeper's Avatar
  • Bad MAP sensor
I am trying to borrow a smoke machine to check for vacum leaks, wouldn't i get a IAC code. My next guess is a short or bad ground that will give me a voltage drop once the AC is one.
AutomagicLS1
Aug 1, 2013 04:53 PM
Shaggy
Jun 13, 2010 08:35 AM
yazan84
May 16, 2008 10:03 PM
bombadee
May 13, 2008 06:54 AM
Sparky
Feb 28, 2007 11:11 PM
