98 blazer falls on its face when throttle fully pressed
Hi, Im new here and am having unusual problems with my blazer. This only happens in the winter time. Summer it never happens. And it dont matter if you have been driving for 2 min or 2 hrs same thing. Its a 98 blazer. If i barely press the throttle it will rev and drive good. But if I mash it or even put it down half way it downshifts and everything fine it just falls on its face and doesnt rev. Like i said summer time fine. Any help would be appreciated. THanks in advance. Jeremy
That's odd. I would get a fuel pressure gauge and see what your pressure is.
Maybe replace your fuel filter.
Is it setting any SES lights? Try unplugging the MAF sensor and see if that clears it up. I just recently went through the same thing. I got a check engine light for a brief moment then it went off. The truck then started doing the exact same thing as yours. I had the code scanned and it was P0101 for MAF sensor. Unplugged the MAF and the truck ran perfect. Tried cleaning the MAF and that didn't help either. Replaced the MAF with a junk yard unit and all is well. Good luck and welcome!
The Cat. Converter plugged! Huh oh well at least i know the problem now.
My 98 is doing somewhat the same thing. Will start instantly and idle, but when tryu to give it some gas, just wont respond. Will not rev up, only slightly. I noticed tho, while idling, It sounds odd from the tailpipe. Anyone????
Here is what I have done so far. I cleaned the MAF with no luck. Today I swapped it out with a junk yard unit. No joy. I unplugged the MAF and it instantly died. I have 60 PSI fuel pressure. I have replaced the cap, rotor, plugs, wires, crank sensor, and the Intake Air Temp sensor. I am at a loss.
LSpoweredStepside
09-30-2013 09:22 PM
HoboWatson
05-30-2012 10:25 AM
A/M/G
30
05-24-2010 08:03 AM
