98 blazer fuel pump?
Old Dec 28, 2010 | 02:55 PM
plneds's Avatar
plneds is on a distinguished road
Default 98 blazer fuel pump?
No Start.Pressure 62 psi when pump runs.58 when pump stops.Holds at 58 for 10 min.Have spark.Will run with the aid of carb spray but dies.Security light goes off on dash and all other lights work.All started with dead battery when vehicle sat for a few weeks.Otherwise had been running fine.No codes in system except c0222 for rt. wheel sensor.With gas from vehicle was able to start a small engine So I assume gas hasn't phased out on me.New cap and rotor. Wires fairly recent.What am I missing?
Old Dec 28, 2010 | 08:50 PM
It definitely sounds like a fuel supply issue. Almost like something is prohibiting the injectors from opening. You could back probe the injector wires and test with a noid light to confirm that theory.
Old Dec 31, 2010 | 07:53 AM
plneds's Avatar
Default Checked with noid light
Well I checked with a noid light and each injector plug pulsed.Would I be able to check injectors themselves by using pressure gauge.I would build up the pressure then remove fuel pump relay then crank engine and see if pressure drops hence meaning injectors plugged or not?
Old Dec 31, 2010 | 08:59 AM
Can you access the injector balance test with your scan tool? Gotta be a good scan tool, the cheapies won't access it. If so, that's the easiest way to compare/check injector performance.
Old Dec 31, 2010 | 09:23 AM
plneds's Avatar
No unfortunately not.But thanks
BouncingRadical
14
Nov 27, 2015 12:30 AM
cide
Nov 7, 2009 01:26 PM
upblazer95
Mar 8, 2009 07:15 PM
Lckyctch
Dec 30, 2007 05:38 PM
mytruck2
Dec 13, 2006 04:50 PM
