'98 blazer heater core went out want to bypass
Old Jun 13, 2009 | 10:56 AM
krystle's Avatar
krystle is on a distinguished road
Default '98 blazer heater core went out want to bypass
I want to bypass the heater core in my '98 4x4 blazer. How do I go about locating the heater core and the hoses without having to go and buy a manual.
Does anyone know what the average cost to pay someone to do this for me?
Since the heater core went out the air has stopped working as well are the two related?
Thank you
Old Jun 13, 2009 | 01:12 PM
Just follow the ~3/4" diameter hoses from the engine into the firewall. It will be right next to the distributor to the passenger side. Pretty easy to bypass. If you cannot connect the hoses together, then just plug the ends.
Is your heater core leaking?
And the two problems can definitely be related. If the vacuum supply to the HVAC system has been compromised in some way, it will have an affect. There are quite a few threads on this subject since it is somewhat common.
Old Jun 14, 2009 | 02:36 AM
krystle's Avatar
Thanks for the help!! I have located the hoses and plan to work on it later today. It dosen't look to be that difficult.
Yes the heater core is leaking. I was quoted 1000.00 to replace and at this time do not have the funds. Maybe by winter when I need the heat I will.
As to HVAC system I will look further into the threads to see if I come up with anything.
Thanks again
Old Jun 14, 2009 | 09:14 AM
cage47's Avatar
cage47 is on a distinguished road
$1000??????!!!!! What a rip. The core itself is only like $40 if I remember correctly. I replaced the heater core in my 98 blazer when I had it. It's a little work. Maybe it's the labor they are soaking you on. But it's not really hard. Just time consuming.
Old Jun 28, 2009 | 08:56 AM
gmc847's Avatar
gmc847 is an unknown quantity at this point
I am in the process of replacing the heater core on my '95. I started on it yesterday and will finish it (with luck) today. I didn't know how much it would cost to have someone replace it but $1000.00 doesn't surprise me. It is time consuming. The part is just under $40.00. I thought about by passing it but I knew eventually I would have to bite the bullet. Good luck!
gomfrddy
Sep 3, 2011 05:44 PM
1manner1
Mar 24, 2011 08:37 PM
meworrynot
Aug 8, 2010 04:03 AM
tilleyvideo
Aug 5, 2009 08:10 PM
BlznAnt
May 8, 2007 07:25 PM
