98 blazer rough idle
Old Nov 10, 2024 | 01:17 PM
  #21
John bates's Avatar
John bates is on a distinguished road
Also I couldn't upload the last screenshot as I have poor WiFi.
This is the data...
Fuel trim Bank 2 Sensor 1, Latest value. - 3.12%
Old Nov 10, 2024 | 01:27 PM
  #22
John bates's Avatar
Also, after thought I have just posted at Idle.
I will redo and come back at 2500rpms
Old Nov 11, 2024 | 05:50 AM
  #23
John bates's Avatar
Hello,
Any upload the images of the results so I will post them instead....
START UP. IDLE. H RPM.. 2500RPM
COLD
FTLT B1 7.03%. 7.03,%. 7.03%. - 7.03%
FTST B1. 0%. 3.12%. - 0.78%. - 0.78%
FTLT B2. 1.56%. 1.56%. 1.56%. - 8.59%
FTST B2. 0%. 3.91%. 0%. -9.38%
Old Nov 11, 2024 | 08:08 AM
  #24
GeorgeLG's Avatar
Originally Posted by John bates
Hello,
COLD
Those values suggest a significant vacuum leak. Have you gone through that process yet?
George
Old Nov 11, 2024 | 10:33 AM
  #25
John bates's Avatar
George
No I haven't looked into vacuum leaks too much.
I changed EGR valve, Maf, IAT
Made sure air intake was sealed along with pipe that goes to valve cover
Old Nov 11, 2024 | 10:39 AM
  #26
GeorgeLG's Avatar
I would go through the process. There’s a few different ways to approach this, usually with some combination of pinching off hoses and spraying propane, brake cleaner, or water, and watching RPMs.
Have you done the lower intake, manifold gaskets yet?
also, if we’re going to start getting in the misfire detection, you’re gonna need to make sure your CMP retard is within spec.
George
Old Nov 11, 2024 | 12:18 PM
  #27
John bates's Avatar
Ok, the car still runs good for a minute or so from cold before running rich.
What android app can I use to check cam retard?
Back history for the truck,
Cylinder heads changed for new 1 year ago
New intake gaskets
Ran great to start with but slowly deteriorated.
It would alway spluttering on acceleration after deceleration and braking.
Old Nov 11, 2024 | 01:37 PM
  #28
John bates's Avatar
Cmp is - 5.8 degrees
So I need to sort this.
Must of been when I done the intake manifold.
Distributor was a pain to get right.
Old Nov 11, 2024 | 02:22 PM
  #29
GeorgeLG's Avatar
Youdo need to get CMP retard sorted but you’re not off by a tooth. You just need to modify the hold down and rotate the distributor until you get within spec. How do you know the truck is running Rich? I thought you said the spark plugs were clean
George
Old Nov 11, 2024 | 02:41 PM
  #30
John bates's Avatar
George
The spark plugs are clean but just assuming its rich as smells like raw fuel out of the tail pipe with black and sooty around the tip of the exhuast too.
