98 Blazer shut off while driving
Old Aug 31, 2024 | 11:56 AM
Jmack's Avatar
Jmack is on a distinguished road
Default 98 Blazer shut off while driving
98 Blazer LT 4wd 4 door
My Blazer shut off while I was driving it. There is about half a tank of gas in it. The low fuel warning light came on. I assuming it is the fuel pump. Could it be anything else?
Old Aug 31, 2024 | 07:13 PM
GeorgeLG's Avatar
It can be a couple of things. Has it restarted? Any codes?
George
Old Aug 31, 2024 | 10:23 PM
Jmack's Avatar
It would not restart. It’s at the shop so I can not check the codes.
Old Sep 1, 2024 | 11:06 AM
GeorgeLG's Avatar
OK, good luck at the shop.
George
Old Sep 2, 2024 | 04:51 AM
Jmack's Avatar
What could it be other than the fuel pump?
Old Sep 2, 2024 | 11:09 AM
GeorgeLG's Avatar
I would have to list dozens off possibilities involving fuel control, ignition, system voltages and grounds, computers, … This is pointless without a truck to diagnose to narrow down the possibilities through testing which is what I assume that the repair shop is doing. If they can’t get it figured out, you get the truck back and you want to proceed I will be more than glad to help you but we are going to need fuel pressure gauge, multimeter, spark tester, code reader, etc.
George
Old Sep 2, 2024 | 12:06 PM
Jmack's Avatar
George
l am confused because in your initial post you said it could be a couple of things. What does voltage grounds have to do with a low fuel warning light being on?
Old Sep 2, 2024 | 12:41 PM
GeorgeLG's Avatar
I did not realize that you did not have the truck and we could not do some initial testing to narrow this down. I am going to bow out on this one and let other members help you. Good luck, I hope that the shop takes care of you.
George
Old Sep 3, 2024 | 11:35 AM
Jmack's Avatar
Anyone else know what else could be the problem?
Old Sep 11, 2024 | 03:45 AM
Shawn66's Avatar
Shawn66 is on a distinguished road
I have a 99 and my fuel gauge was working when it wanted to then it died and left me on the side of the road, it was my fuel pump, now yours could be a number of things like injectors or computer, just about anything but with the gauge acting up I would say its most likely the fuel pump, its easy to replace even with fuel in the tank its easy to get down and replace the pump, and they are not expensive at all I got mine on Amazon for $32 had it done in less than an hour, just be careful with the fuel lines that plastic is easy to break if you are not careful.
03jawja
Performance & Brainstorming
Aug 27, 2020 12:06 PM
nlgank
Feb 20, 2015 09:31 AM
yhandor
Feb 7, 2012 01:23 AM
Qmulus
Mar 21, 2010 01:02 PM
