98 Blazer - Signal Lights issue...wtf
Old Aug 24, 2012 | 02:11 AM
danno_'s Avatar
danno_ is on a distinguished road
Default 98 Blazer - Signal Lights issue...wtf
Working on my 98 Chevy Blazer and having issues with my signal lights. So here's the issue:
Right signals - work fine on front & rear
Left signals - cause signal relay in glove box to "grind" or click very fast.
Hazard lights - don't work at all. no sign from signal relay or dash etc.
Can't figure out where my issue is. Changed signal relay flasher (black box in glove box) and checked all fuses and check OK!
If someone has the answer to this please let me know. Could it have something to do with the trailer wiring? Any ideas short of chasing all the wiring around the truck would be helpful.
Old Aug 24, 2012 | 12:37 PM
BlackcombJimmy's Avatar
BlackcombJimmy is on a distinguished road
Glad to know im not the only one having this issue. Funny all the bulbs work the left side just blinks twice as fact. Anyone come across this issue before, i got a buddy thats an electrical engineer so maybe ill bring it to him lol
Old Aug 24, 2012 | 07:53 PM
spittybays
Guest
Posts: n/a
Hey guys the signal flashers are like behind the cigarette lighter and there round.
Old Aug 25, 2012 | 08:27 AM
midnightbluS10's Avatar
midnightbluS10 can only hope to improve
You probably have a bulb out. Make sure the rear bulb works correctly. It should light up for tails, brakes, and turn signals. I'm betting your brake light portion is blown. Make sure the turn signal and side marker are working up front, also.
Old Aug 25, 2012 | 10:41 AM
cmanning's Avatar
cmanning is on a distinguished road
Just FYI, learned this on a '98 S-10. It might be the switch on the steering column that was part of the directional arm/cruise/washer/wiper. Maybe different on Blazer.Just a thought. Had the same phantom issue and the arm replacement fixed it.Good Luck.
Old Aug 26, 2012 | 08:44 AM
cmanning's Avatar
Danno, The switch on the column that we replaced to correct the problem WAS on the 2000 Blazer. Found the fix and schematic when I first joined this Forum last year.I'd love to find out if this helps.
Old Aug 26, 2012 | 11:43 AM
viper1ex19's Avatar
viper1ex19 is on a distinguished road
If you don't find a burnt out bulb, have a look at the TRAILER LIGHTS WIRING HARNESS. Has anyone messed with the wiring harness for the trailer lately?
These things can drive you nuts with issues that have nothing to do with lights.
There are two white wires in the tail light harness, the smaller one is NOT a ground, it is part of the loop that your cruise control/speed sensor is connected to.
"DON'T MESS WITH THAT ONE"
Good Luck and please follow-up with results or solution.
Thanks in advance,
7outblazer
Aug 12, 2010 05:55 PM
R2P
Nov 1, 2009 08:03 PM
transformer
Apr 18, 2009 03:20 AM
Sterling
Jul 31, 2008 10:50 AM
rryker
Apr 25, 2006 04:14 PM
